I need users to be able to enable/disable Things with a toggle button. Is there a way to check if a Thing is enabled/disabled?
Never mind. Found it.
//input: thingname
// enabled: BOOLEAN
var enabled = Things[thingname].IsEnabled();
//input: thingname
// enabled: BOOLEAN
