It seems that when I combine infotables with "union" their meta data do not get combined. Is there a way to combine the meta data as well? Meta data are fields such as source, timestamp, tags, location, etc. The infotables are query results from a data table. When I set the output of the service as "INFOTABLE" and "infotable type" to "is Data Table", I still do not get the meta data.
let tableLength = someInfoT.rows.length;
for (let x = 0; x < tableLength; x++) {
let row = someInfoT.rows[x];
//Your code here
let query = {
"filters": {
"type": "And",
"filters": [{
"type": "EQ",
"fieldName": "SomeID",
"value": row.SomeID
"type": "LT",
"fieldName": "SomeDate",
"value": oneYearAgo
let queryResult = Things["SomeDataTable"].QueryDataTableEntries({
maxItems: undefined /* NUMBER */ ,
values: undefined /* INFOTABLE */ ,
query: query /* QUERY */ ,
source: undefined /* STRING */ ,
tags: undefined /* TAGS */
// result: INFOTABLE
result = Resources["InfoTableFunctions"].Union({
t1: result /* INFOTABLE */ ,
t2: queryResult /* INFOTABLE */
Hi @Willie.
Did you provide the full code snippet? If so, it looks like you're missing one of the tables you're trying to join.
What version of ThingWorx are you running?
Regards
--Sharon
Hi @slangley
No, I just included the pertinent lines as the service is a lot longer.
I wrote separate test services to see if infotable union includes meta data. Based on my tests, it seems that it does if it is not in a for loop. The output of the code below included meta data.
let query = {
"filters":{
"type": "EQ",
"fieldName": "key",
"value": 55
let infoT1 = Things["SomeDataTable"].QueryDataTableEntries({
maxItems: undefined /* NUMBER */,
values: undefined /* INFOTABLE */,
query: query /* QUERY */,
source: undefined /* STRING */,
query = {
"filters":{
"type": "EQ",
"fieldName": "key",
"value": 60
let infoT2 = Things["SomeDataTable"].QueryDataTableEntries({
var result = Resources["InfoTableFunctions"].Union({
t1: infoT1 /* INFOTABLE */,
t2: infoT2 /* INFOTABLE */
query = {
"filters":{
"type": "EQ",
"fieldName": "key",
"value": 70
let infoT3 = Things["SomeDataTable"].QueryDataTableEntries({
t1: result /* INFOTABLE */,
t2: infoT3 /* INFOTABLE */
However, I noticed that when the infotable union occurs in a for loop, it does not include meta data. The output of the code below did not include meta data.
var result = DataShapes["DataTableB.DS"].CreateValues();
let oneYearAgo = new Date() - 31536000000;
let infoTA = Things["DataTableA"].GetDataTableEntries({
maxItems: 20 /* NUMBER */
let tableLength = infoTA.rows.length;
let row = infoTA.rows[x];
//Your code here
let query = {
"filters": {
"type": "And",
"filters": [{
"type": "EQ",
"value": row.SomeID
"type": "LT",
"value": oneYearAgo
let infoTB = Things["DataTableB"].QueryDataTableEntries({
t2: infoTB /* INFOTABLE */
Hi @Willie.
In your 2nd example that doesn't include the metadata, it appears you have failed to combine tA and tB. The t1:result doesn't exist:
result = Resources["InfoTableFunctions"].Union({ t1: result /* INFOTABLE */ , t2: infoTB /* INFOTABLE */
Regards.
--Sharon
Hi @slangley
Not sure what you mean. result is declared in the first line. It is empty initially, but as it goes through the for loop, it gets rows added.
Hi @Willie.
It looks like you're performing a union with an empty info table. You might want to review your code in the 2nd example where it's not working.
Regards.
--Sharon
Hi @Willie.
Have you been able to resolve your issue or do you still have questions? Please let us know.
Regards.
--Sharon
So it seems that the union function has a limitation where if one of the infotables is empty, it will not add the meta data.
Hi @Willie.
Why would the infotable be empty? What is the use case? If needed, you could use some conditional logic to not perform the union if the infotable is empty.
Regards.
--Sharon
