Hi everyone!
I'm using value display to show an information that I have received from my PLC.
The information is ok. But I was not able to configure the color that value display.
What's property I change this color?
Hi @einsfeldleo
It appears this is a defect that has been documented at https://www.ptc.com/en/support/article?n=CS316985 .
If the value is not bound, then the style applied to string > value-container works, but if the value is bound, the default style remains.
As a workaround you can define your own Style Theme, set the color for Colors > Text Colors > Body
Then apply the style Theme to the value display in the mashup.
Then the value dispaly text follow the color define in style theme:
value display text follow the style theme
Hope this helps
Christophe
Hi @einsfeldleo
Hope this helps
Christophe
Hi @cmorfin
Thank you for your answer! You was able helped me.
I have other question:
I wanna centralize my data into value display, but it don't work. Follow image below:
In the image above I would like that "information" stayied in the middle (blue). My value display is all source in gray.
I have changed the properties to center, but don't work.
How do I do it?
Hi @einsfeldleo
I am afraid this appear to be a defect.
I have reported this to R&D, see https://www.ptc.com/en/support/article?n=CS319193
Kind regards
Christophe
Hi @einsfeldleo.
This issue is being addressed in ThingWorx 9.0 targeted for the May timeframe.
Regards.
--Sharon
