What is the best way for configure timer which will check changes(like adding/updating/removing file) in my file repository and get info about created/updated/removed file(like name, date of changing etc.)
There are a few ways to approach this.
1. There is a FileTransfer event, you can subscribe to that, this works when the Copy command is used.
2. There is a REST API (all thingworx content is automatically available as rest), so if you are making changes etc. You could chain a rest call to then execute processing of said changes.
3. A Timer, not too sure what exactly you are looking for, but if you use a timer, then you will need to go to the necessary repositories, retrieve the content details and somehow determine new, old, changed, removed etc. I don't think you will find a trail anywhere unless you create it yourself (store snapshots in a DataTable potentially)
Actually FileTransfer event not triggered every time when we upload files, so I choose the solution, when we monitoring directories using timer and FileRepository services
Right, that means you will have to do a bit of extra work.
Again you could consider the REST API call to trigger the necessary services if you have that ability from the places you are sending the files from.
