How to consume SOAP Web service in thingworx?
rsalunkhe
I want to call SOAP web service from thingworx which is wrote in JAVA. I use getXML snippet for same. But I can not understand prameters we need to pass in snippet. Please suggest solution fotr this. Also we need to send some parameters for calling web service. How can we pass parameters using getXML?
Here you have a sample of my last SOAP consume implementation:
var content ='<x:Envelope xmlns:x="http://schemas.xmlsoap.org/soap/envelope/" xmlns:wsd="https://mydomain.com/wsdl">\
    <x:Header/>\
    <x:Body>\
        <wsd:remoteSoapServiceName/>\
    </x:Body>\
   </x:Envelope>';
var resultXML =
  Resources["ContentLoaderFunctions"].PostXML({
  proxyScheme: undefined /* STRING */,
  headers: undefined /* JSON */,
  ignoreSSLErrors: undefined /* BOOLEAN */,
  useNTLM: undefined /* BOOLEAN */,
  workstation: undefined /* STRING */,
  useProxy: undefined /* BOOLEAN */,
  withCookies: undefined /* BOOLEAN */,
  proxyHost: undefined /* STRING */,
  url: "https://mydomain.com/service/wsfia/compub" /* STRING */,
  content: content,
  timeout: undefined /* NUMBER */,
  proxyPort: undefined /* INTEGER */,
  password: undefined /* STRING */,
  domain: undefined /* STRING */,
  username: undefined /* STRING */
var returnXMLString = resultXML.*::Body.*::remoteSoapServiceNameResponse.return;
var str = ""+returnXMLString[0].toString().replace(/\n/gi,"");
9 REPLIES 9
    <x:Header/>\
    <x:Body>\
    </x:Body>\
   </x:Envelope>';
var resultXML =
  content: content,
Hi Carles,
I followed your code but doesn't helpful for me. Here is my code
var content = '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:hs="http://www.holidaywebservice.com/HolidayService_v2/">\
<soapenv:Body>\
<hs:GetHolidaysAvailable>\
<hs:countryCode>UnitedStates</hs:countryCode>\
</hs:GetHolidaysAvailable>\
</soapenv:Body>\
</soapenv:Envelope>';
var params = {
url: "http://www.holidaywebservice.com//HolidayService_v2/HolidayService2.asmx?wsdl" /* STRING */,
// result: XML
var result = Resources["ContentLoaderFunctions"].GetXML(params);
My updated code is below: following error occurs: I Parse XML namespaces as per https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS219642&lang=en&source=snippet
Unable To Convert From org.mozilla.javascript.xmlimpl.XMLList to XML
<soapenv:Body>\
</soapenv:Body>\
var params = {
content: undefined /* XML */,
// result: XML
var xmlPage = Resources["ContentLoaderFunctions"].GetXML(params);
var result = xmlPage.*::soap.GetHolidaysAvailableResponse.GetHolidaysAvailableResult
Here is <soap:envelope> response from Postman:
<?xml version="1.0" encoding="utf-8"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
    <soap:Body>
        <GetHolidaysAvailableResponse xmlns="http://www.holidaywebservice.com/HolidayService_v2/">
            <GetHolidaysAvailableResult>
                <HolidayCode>
                    <Code>NEW-YEARS-DAY-ACTUAL</Code>
                    <Description>New Year's Day</Description>
                </HolidayCode>
                <HolidayCode>
                    <Code>NEW-YEARS-DAY-OBSERVED</Code>
                </HolidayCode>
                <HolidayCode>
                    <Code>MARTIN-LUTHER-KING-BIRTHDAY-ACTUAL</Code>
                    <Description>Martin Luther King's Birthday</Description>
                </HolidayCode>
                <HolidayCode>
                    <Code>MARTIN-LUTHER-KING-BIRTHDAY-OBSERVED</Code>
                </HolidayCode>
                <HolidayCode>
                    <Code>GROUNDHOG-DAY</Code>
                    <Description>Groundhog Day</Description>
                <HolidayCode>
                    <Code>ASH-WEDNESDAY</Code>
                    <Description>Ash Wednesday</Description>
                </HolidayCode>
                <HolidayCode>
                    <Code>VETERANS-DAY-OBSERVED</Code>
                    <Description>Veteran's Day</Description>
                </HolidayCode>
                <HolidayCode>
                    <Code>NEW-YEARS-EVE</Code>
                    <Description>New Year's Eve</Description>
                </HolidayCode>
            </GetHolidaysAvailableResult>
        </GetHolidaysAvailableResponse>
    </soap:Body>
</soap:Envelope>
You should be referencing XML nodes wrongly, I'm not super used to it, and if you aren't, you should test variations on how to reference it, and/or understand well.
Try to recover first a lower level on the XML hierarchy for instance.
On my case once I got the answer, I had to convert to string, remove new lines and convert back again to XML ( with a in memory property of type XML ).
Carles.
Hi Carles Coll​,
Your support is valuable for me.
Your code is very helpful. But data comes with xml tag. Following is my code. I created SOAP_DataShape and create infotable from that datashape. In for each I parse xml according to tags. You can see xml directly hitting url in browser.
var params = {
url: "http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx/GetCountriesAvailable" /* STRING */,
// result: XML
var resultXML = Resources["ContentLoaderFunctions"].GetXML(params);
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "SOAP_DataShape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(StringDataShape)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
for each (var tag in resultXML.*::CountryCode.*::Code) {
    var newRow = new Object();
    newRow.HolidayCode = tag;
    newRow.Description=tag;
    result.AddRow(newRow);
Here is URL: http://www.holidaywebservice.com/HolidayService_v2/HolidayService2.asmx/GetCountriesAvailable
I want only value extracted from tag. What should I do for it??
Here is my output. Please add your comments. And you
Your reply is valuable for me.
Fast solution : tag.replace('<Code xmlns=......","").replace("</Code>","");
Carles Coll
It gives following error
TypeError: INVALID_CHARACTER_ERR: An invalid or illegal XML character is specified. (Demo_SOAP#31)
Hi Carles Coll​,
My first call of SOAP is successful but bad luck for second call. can you check my code? It returns empty response. It works fine in Postman. But not work in TW. Here I pass "United States" as parameter to "countryCode"
Note: I am using wsdl file here.
<soapenv:Body>\
</soapenv:Body>\
var params1 = {
// result: XML
var resultXML = Resources["ContentLoaderFunctions"].GetXML(params1);
var params2 = {
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params2);
for each (var tag in resultXML.*::HolidayCode) {
    newRow.HolidayCode = tag.*::Code;
    newRow.Description=tag.*::Description;
