How to count asset in thingworx license
Nuttapol
11-Garnet
I don't understand about asset in thingworx.
one asset mean one thing or one asset mean one device connect to thingworx or other
if one asset mean one thing when i create thing  by not connect device i will lost one asset right?
Please suggestion thank you
8 REPLIES 8
Definition of an Asset as described in PTC Software Products Licensing Basis.
“Asset” (designated as “IoT”) (also sometimes referred to in the product itself or elsewhere as a “Device” or a “Thing” or a “Remote Thing”) means a sensor, device, machine, system, web service, etc. that is modeled (represented) and/or registered as an asset (or “device” or “thing” within the Licensed Product) or any separately defined part of the foregoing if it is being treated as a separate asset within the software. For example, without limitation, an Asset could be a brake press, industrial dryer, another computer system, or a set of individual components within those machines if modeled or registered as a separate asset in the software), etc.
Thank you for you suggession rjanardan.
I've read this manual before but i'm not sure.
OK I have another question.
if i need to know i have how many asset.
can i see number of asset from Licensing Subsystem Settings>twx_things right?
Such as i have SCP Premium Edition license will have twx_things limit = 50 yes or no?
Yes, you're correct. twx_things represents the limit.
s_sirapol
(To:rjanardan)
Hello, I have more question.
You say "Asset is Thing".
If I using schedule , DataBaseThing , Timer , MQTT Thing , Gateway Thing.
It's count in to Thing.
That mean "Asset" right?
I think it not make sense for count the Timer and schedule in Asset.
twx_things is a feature name in the license file that determines the maximum allowed assets. Refer this article on how to check connected assets or users.
I following you instruction.
I found 3 asset count in my license.
I try to create thing, industrial connection and etc.
It is not count more 3 asset.
I would like to know " How to count asset ?".
Hello, Can you tell me "How to count?
Hi @ssriuaipornchai.
I suggest that we open a case for your remaining questions to confirm everyone is on the same page.  With your approval, I will be happy to open the case on your behalf.
Regards.
--Sharon
