Hi @slangley ,
We are unable to customize the Thingworx Organization login screen.
Found a similar question posted in the community in the following link:
https://community.ptc.com/t5/ThingWorx-Developers/is-it-possible-modify-login-page/td-p/516808
We are unclear as to how the SSO can be achieved. Can you please help us out with a detailed explanation?
Also, If we create an external Login page and SSO into ThingWorx, can we still control and maintain the user, usergroup, Visibility, run time and design time controls via ThingWorx?
If you are interested in using SSO with ThingWorx then this document PTC Single Sign-on Architecture and Configuration Overview https://www.ptc.com/en/support/refdoc/ThingWorx_Platform/8.0/PTC_Single_Sign_on_Architecture_and_Configuration_Overview_Guide_172779?&posno=1&q=sso%20architecture&DocumentType=Reference%20Document&source=search
provides an overview.
Thank you. will go through the document.
Also, i would like to know, If we create an external Login page and SSO into ThingWorx, can we still control and maintain the user, usergroup, Visibility, run time and design time controls via ThingWorx?
Hi @Dabbler_Aish.
If the responses provided by Marek answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
