How to create json from infotable using ToJson method?
bgupta-2
Dear Team,
I am getting tabular data  after calling below code as result output is JSON.
var params = {
    oldestFirst: undefined /* BOOLEAN */,
  maxItems: undefined /* NUMBER */,
  sourceTags: undefined /* TAGS */,
  endDate: undefined /* DATETIME */,
  query: undefined  /* QUERY */,
  source: undefined/* STRING */,
  startDate: undefined /* DATETIME */,
  tags: undefined /* TAGS */
// result: INFOTABLE
var result2 = Things["PumpValueStream"].QueryStreamEntriesWithData(params);
var params = {
  table: result2 /* INFOTABLE */
// result: JSON
var result = Resources["InfoTableFunctions"].ToJSON(params);
posipova
20-Turquoise
(To:bgupta-2)
Hi, below is a simple example of using toJson snippet, converting from an existing infotable (with a datashape) to json:
Or with a query,
Keep in mind such a result would be displayed in a tabular format. However, you may save it to, for example, a property
result = table1.ToJSON();
Then when the property is assigned the converted toJson data, you will see the following:
