I was working on user creation script. few users has been created by non editable mode. I am able to see those users via GetAllEntities() not in composer,
Also, i found a way to see users in composer by creating one service to add users in particular usergroup after adding them I am able to see added(non editable) users in that usergroup.
In Usergroup if i click and delete user nothing happens,if I try to change property I get you can't delete non editable users.
Now I added 10+ undefined users in that group. Now, I need to remove the users from my instance.. I tried via deleteuser service but users are not deleted and still I am able to see them via GetAllEntities()...
Hi @sabharees.
It sounds like something is missing from your script used for creating the users. Can you provide that so we can take a better look? Also, what version of ThingWorx are you running?
Have you checked the logs located at \ThingworxStorage\logs for clues?
Regards.
--Sharon
I am using .. ThingWorx 8.5.4,
yes, as you said I missed fieldvalues at the execution of the service but later I figured the cause of issue and corrected my code. Now, user creation is working fine but I am not able to delete previously created users(non editable).
Hi @sabharees.
Have you tried running an update script to populate the missing fields, and then deleting it?
Regards.
--Sharon
Hi @sabharees.
Have you made any progress in resolving your issue? If so, please share the details of your solution with the community. If you're still working to resolve it, I recommend we open a case. I will be happy to open one on your behalf.
Regards.
--Sharon
Hi @slangley , Thanks for your response. But currently, I am working on other tasks So I've not made much progress on this.
