[TWX Flow 9.0.2] - Boolean Input for Flow Actions
DanZ
I try to execute a Thingworx service (Action "Service Execute") with a boolean input value in a Flow. The Boolean input parameter for the executed action is given from the input parameter (also Boolean) from the Flow itself.
The issue is that I cannot bind the Input params (oder params from other actions) to the Boolean input (like I could with any other input type like a String). I only can choose between a fixed true or false; see attached image.
There is a option to not use the "Form" input a apply a JSON, but that does not work either. Because my second input variable (which is a String) is getting ignored somehow.
(i.e. {"BoolVar":{{$Service.BoolInput}},"order":{{$Service.orderNo}}} )
I don't like workarounds like:
- Duplicate the action (one with "true", the other with the "false" input)
- Change the input variable of the Thingworx service from Boolean to String
because this is a fairly simply use case and it just would make things more complicated (or harder to understand for third parties) as they are.
Is this a bug? Or is there a reason why I can't bind Boolean Inputs for the "Service Execute" Action?
gnandyala
(To:DanZ)
Hi danz,
We have checked this now in 9.0.1 and it is working as required with two json inputs
Thank you,
Gautham
10 REPLIES 10
gnandyala
(To:DanZ)
Hi DanZ,
Looks like a bug i will dig in if there is a reason why this is disabled.
Thank you,
Gautham
gnandyala
(To:gnandyala)
Hi DanZ,
I can confirm it is working that way.
I will find the reason why the boolean input is getting ignored.
In case you want this functionality you can open a ticket with us.
Thank you,
Gautham
gnandyala
(To:gnandyala)
Hi DanZ,
This is a bug. We are working on fixing it.
Thank you,
Gautham
gnandyala
(To:DanZ)
Hi Danz,
We created a Nodejs Action that gave a boolean result and appended that result in Service Execute action.
Note: Used option AssignJson
We were able to run it boolean2.pngboolean.pngSuccessfully.
DanZ
(To:gnandyala)
have you tried using a second parameter? I had problems when using the Assign JSON input because my second input param was getting ignored. The boolean input itself worked fine.
gnandyala
(To:DanZ)
Danz,
Second parameter works as well.
Can you send me your entity so i can test it.
Thank you,
Gautham
DanZ
(To:gnandyala)
I don't have the flow nor the entity anymore. The fact that the issue will be solved with a new Thingworx version is good enough for me.
Maybe I missed something past then when i tried to use the assignJSON option.
Thank you.
gnandyala
(To:DanZ)
Hi danz,
Thank you,
Gautham
gnandyala
(To:gnandyala)
Thank @DanZ,
There is no update coming to this in future release. It is working as expected.
slangley
(To:DanZ)
Hi @DanZ.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
