How to display 2 texts from 2 services in single label by toggling?
bmarimuthu-2
First I explain what I have done in above screen. Here "Run communiction Test" button  is overlayed by "continue" button. On clicking,I have set visibility as false for those 2 buttons using 2 different expression widgets. And I have used a validator " Run comm" that returns true value on clicking of "Run communication Test" binded to visibility of  label in "system message" fieldset So that it ill be visible only after clicking of   "Run communiction Test" button.
My requirement is,
I have a label in "System Message" fieldset. On clicking of "Run communiction Test" button, it has to display the "result message "column from "spLocal_comEnteGreatScaleCom_Run_Test" stored procedure
Similarly, On clicking of "continue"button, it has to display the "result message "column from another stored procedure"spLocal_comEnteGreatScaleCom_Evaluate_Test"
Please help me out of this!!
PaiChung
22-Sapphire I
(To:bmarimuthu-2)
These unfortunately are the most challenging within Thingworx since it is Source to Many, Target of One
What you can probably do is the following
Create a Session Parameter
have each service that runs, in the Server side update the Session Parameter with the label value
On the Client side do a GetSessionParameterValues service to retrieve the label information
have it triggered on Service Invoke complete of either service.
