How to display image property on mashup?
ptc-2261104
Below is my scenario for manufacturing plan monitoring
Each plan will have more than 6 production lines and each line will have stations from 4 to 8
Requirement 1:
When user selects any production line i would like to display a line layout with stations (I can create image for each line with stations). I created property of type IMAGE for line ThingShape(ThingTemplate) and uploaded image while creating production-line Thing. How to display this image on mashup - image widget accepts only Source URL/Media.
Requirement 2 (not sure if this is possible)
In production-line layout image I would like to highlight a station with specific color based on its KPI/current state of the station.
At least i would like to meet requirement 1.
5 REPLIES 5
Hi Ketan,
You have a couple of options with regards to your first requirement. Rather than store the image as a property of a
Thing
, you can set the avatar of the
Thing
to the image using
SetAvatar()
and retrieve it using
GetAvatar()
or
GetAvatarURL()
. With this approach, you're able to use the Image widget (
GetAvatarURL()
returns a MEDIALINK) and you won't be creating an extra
Property
. Your other option is to use the Value Display widget to display the image which can display just about anything you throw at it.
For your second requirement, this seems like a situation where you'd want to use
State Definitions
and state-based formatting. You can reference section 04.03 Styles and State Formatting of the Wiki for more information. Are trying to change the actual image or a background image or similar?
Adam
Thanks Adam,
For second requirement. I would like to use the production-line image from requirement 1. As i said the production-line will have many stations (production line image will show stations as small icons) and we would be monitoring all stations. This is more like visualization of production line layout which shows small green/orange/red dot on production-line image for each station based on status.
I can share sample image of production-line if you need. I don't see option to upload t here.
-Ketan
Thanks Adam,
-Ketan
Thanks Adam,
-Ketan
Hi Ketan,
You can access your company's File Repository from the My Forum tab on the homepage.
