I have a datatable containing customers and their locations. This is bound to a google widget and the locations all show up fine. However, when I select 'show route' as TRUE, i just get straight lines between the points. How do I get the google map widget to show a routing along roads between the points? Should work, maybe something is out of sorts with the widget?
Message was edited by: Polina Osipova
Hello, so ShowRoute isn't actually supposed to be a tool for navigation, which doesn't currently exist at all in this widget. ShowRoute is supposed to show the locations over time so you can track things. I am not sure exactly why they are appearing as straight lines, but I do know that this isn't the purpose of ShowRoute. Because the locations aren't actually related to one person traversing a route, then that is probably why it appears funky.
If you think that ThingWorx should add navigation route functionality to the widget or if you want a real explanation of what you're seeing, I'd try opening a case and attaching an entity export for review.
Hope this helps!
Tpro
Thanks Tori. That helps. The scenario is that we're following a delivery truck with its various systems reporting. This would be applicable to a lot of scenarios and I'll pursue the addition of routing info for the widget.
Rob
