I have a repeater and i have to display the relevant data in a separate panel from the data table when a button/value display widget is selected in another panel.
But i'm getting the first row values from the data table, how can I get the relevant row values for each button/value display widget?
Thanks for support!
Check to see if you are using Selected Row(s) vs. All Data.
Usually if you bind from All Data you see the first row all the time.
okay.
Can you say, how can i connect the ValueDisplay/Button widget to display Selected Row data to another panel ?
Thanks for support!
Hi @alekhya
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Please open a separate thread for the new question.
Regards-Mohit Goel
