Hi There,
I was trying to enable full-screen mode by clicking a button instead of f11 option.
I used the following HTML code as a normal HTML file, works cool.
<button onclick='document.documentElement.webkitRequestFullscreen();'>Go Fullscreen Mode</button><button onclick='document.webkitExitFullscreen();'>Close Fullscreen</button>
I also tried HtmlTextArea widget with the read-only option enabled, Not getting the expected result.
Even I tried WebFrame widget to call the HTML file and execute, not worked.
Give me a solution if exist.
Add an Expression widget and on the expression field set:
($("#runtime")[0].webkitRequestFullScreen()?$("#runtime")[0].webkitRequestFullScreen():($("#runtime")[0].mozRequestFullScreen()?$("#runtime")[0].mozRequestFullScreen():$("#runtime")[0].msRequestFullscreen()?$("#runtime")[0].msRequestFullscreen():$("#runtime")[0].requestFullScreen()))
Then when you want full screen you just need to trigger this expression (from a button Click event, should be started by a user clicking the button)
Works for FullScreen!
I tried the following combinations two ExitFull Screen, Not Working..,
($("#runtime")[0].webkitExitFullscreen()?$("#runtime")[0].webkitExitFullscreen():($("#runtime")
[0].mozCancelFullScreen()?$("#runtime")[0].mozCancelFullScreen():$("#runtime")[0].msExitFullscreen()?$("#runtime")[0].msExitFullscreen():$("#runtime")[0].exitFullscreen()))
($("#runtime")[1].webkitExitFullscreen()?$("#runtime")[1].webkitExitFullscreen():($("#runtime")
[1].mozCancelFullScreen()?$("#runtime")[1].mozCancelFullScreen():$("#runtime")[1].msExitFullscreen()?$("#runtime")[1].msExitFullscreen():$("#runtime")[1].exitFullscreen()))
How I exit the FullScreen?
You can't control exiting full screen from within the page, should be the user with "ESC" keyboard key.
What if keyboard is not available ???
Keyboard on screen :P
