What I'd like to do is to have ThingTemplate with ConfigurationTable with some fields and ThingShapes with services implementation that uses fields from that ConfigurationTable. Both template and shape are from java extension. The main purpose of that is to enable user to select (through editable template) which services he want in his Thing. Is there an easy way to get those ConfigurationTable fields from Template in ThingShape?
Adrian
How are you guaranteeing that the thing shapes are only applied to your thing template? How do you intend to control what services are available on a thing, and what is the use case you're attempting to solve here?
