How to get current mashup url at runtime
travman7777
@MDUser, were you able to resolve this question? I have a similar need. I have a redirect page from a third party application in which they append parameters to the url, and I need access to those param values.
Hello @travman7777 ,
I have checked the query raised by the user you have mentioned in the description. Their rquirement could not be fulfilled since fetching the mashup name is not feasible in ThingWorx without using some hardcoding (like using mashup parameter for every mashup).
pls check the linked article if that helps you:
https://www.ptc.com/en/support/article/CS187026
Bhawna
Bhawna
Thank you for following up. Yes I can confirm that was the way we ended up accessing the paramters. Ie hard coding them in the mashup.  In our case this should be sufficient for the time being.
