How to get the unique column values from 2 infotables
vi1
I have 2 infotables.
How to filter the unique column values from 2 nd table compared to 1st table column values..
I have tried to use "Intersect" but its giving the same column values .
Example:
 first table columns: path, description
 second table columns: path, ThingName etc
if first table column path value is not matches the 2nd table column path, then return the 2nd table path.
Thank you in advance.
Use RIGHT join instead of INNER on intersect snippet
slangley
(To:CarlesColl)
Hi @vi1.
If the response provided by Carles answered your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
