ThingWorx Installation Problems
rao91
2-Explorer
I am trying to install ThingWorx 8.3 H2 using the .war file. I am downloading the .war file from here - https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX. I am following the following steps -
1. Java JRE installation
2. TomCat 8.5 Installation
3. Running http:localhost:8080
4. Deploy the .war file
At the end of step 4, when I try to deploy the .war file the local host fails to open. I browser throws an error "this site can't be reached' ...
PS: I am following the instructions from this tutorial - https://community.ptc.com/t5/IoT-Tech-Tips/ThingWorx-Tutorials-Installing-ThingWorx-Neo4j-in-Windows/td-p/532555
Pawan Rao
slangley
23-Emerald II
(To:rao91)
Hi @rao91.
Did you install 64-bit Java?  If so, please provide the \ThingworxStorage\log\ApplicationLog.log and <Tomcat_home>\logs\catalina.log.
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @rao91.
Circling back to your original post, did you find a solution to your problem?  If so, please post it here and mark it as the Accepted Solution for the benefit of others on the Community who may be experiencing similar issues.
Regards.
--Sharon
