How to hide selected item in ptcsdropdown when filter is active
AK_9796023
6-Contributor
need the function to hide selected dropdown item when dropdown filter is active
Thanks in advance
PaiChung
22-Sapphire I
(To:AK_9796023)
Do you mean a selection in the drop down, or the whole drop down?
Can you also explain the reason why this is necessary?
AK_9796023
6-Contributor
(To:PaiChung)
I mean if e.g. "22-5" was selected before and then "12" is entered in the filter input field of the dropdown, "22-5" is also displayed in the list even though it does not match the filter criteria
PaiChung
22-Sapphire I
(To:AK_9796023)
There used to be a custom widget with this exact behavior, not sure if that exists still or not or if it at all made it into product.
I would say that a custom widget would be the way to go as I don't think the standard drop down support this right now/yet?
