How to insert or Add values in between Two rows in a Grid widget
H_1234
11-Garnet
I need a requirement like is there any possible way to add values in between two rows in grid widget.
In Grid i research a lot to insert a value in between two Rows.
Required assistance for the query .
Hareef.
kazunari
(To:H_1234)
The easiest way is to sort the table after row insert. You can enable sort in configuration(from gearbox icon) in Grid widget.
