I'm trying to install using the Linux installer from the website but not able to proceed anywhere
for ThingWorx foundation server installation follow this attached document
this is the manual guide is there any guide for using the installer.run file
Could you please confirm if you have installed TWX, So that we can proceed for Analytics.
Are you trying to run a trail version? You can directly run the installers. Do let me know in case of any question.
Regards-Mohit
Did you try to run run Analytics installer? Is there any error could you please confirm.
Regards-Mohit
Hi @mahitejg.
If you have found a solution to your problem, we would love for you to post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
