How to install thingworx foundation and analytics server 8.3.2 on ubuntu 18
mahitejg
I'm trying to install using the Linux installer from the website but not able to proceed anywhere
6 REPLIES 6
for ThingWorx foundation server installation follow this attached document
mahitejg
(To:rosharma)
this is the manual guide is there any guide for using the installer.run file
mgoel
(To:mahitejg)
@mahitejg
Could you please confirm if you have installed TWX, So that we can proceed for Analytics.
Are you trying to run a trail version? You can directly run the installers. Do let me know in case of any question.
Regards-Mohit
mahitejg
(To:mgoel)
hi @mgoel I did install the liniux twx using installer
mgoel
(To:mahitejg)
@mahitejg
Did you try to  run run Analytics installer? Is there any error could you please confirm.
Regards-Mohit
slangley
(To:mgoel)
Hi @mahitejg.
If you have found a solution to your problem, we would love for you to post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
