Hello Expert,
How to log the location and speed in a new stream, using a new Timer Thing??
And What is the Timer Thing and How to use it?
I want to create a new subscription with TimerThing.
Hi Ji young Lee,
Please check this post to understand the timers. Timers and Schedulers - Best Practice
Timer generates an event named timer every x milliseconds as defined in the configuration.
While creating the subscription select the timer thing (Thing which has Timer as Thing template) and write your custom code to add an entry in the Stream.
