How to make the timeserieschart having the axis Y with unit property?
向郭
7-Bedrock
posipova
20-Turquoise
(To:向郭)
I believe such a feature is not available out of the box.  I will verify it during the U.S. business hours  on Monday, and if not, see if there's an existing enhancement request.
You may also look into custom extensibility and creating your own widget that would fulfill your requirements. Let me know if you would like documentation on that.
向郭
7-Bedrock
(To:posipova)
Thank you Polina ,and yes, i need some documention about how to custom the widget.
posipova
20-Turquoise
(To:向郭)
Please find the files attached.
ankigupta
(To:向郭)
Hi Xiang Jing Guo​,
In addition to this you can use the code of existing widgets as base for your custom widget.
These are available at webapps\Thingworx\Common\thingworx\widgets.
Please make sure to NOT make any changes in the folder. Just copy the required widget code to somewhere else and rename the folder and also make corresponding changes in the code.
Ankit Gupta
