9-Granite
January 27, 2023
How to make two grids scroll in sync
  • January 27, 2023
  • 5 replies
  • 4150 views
Hi Team,
I have two datasets displayed in two different grids, I need to make one scroll bar that works for both of them.
any suggestions?
Best answer by PEHOWE
Hello @aitc-plmsupport ,
I always like a working example better then a description.
There are 2 different mashups in this example:
  • Case-Community-dualGrid-V3-Mashup
    • Shows 2 grids with a button which creates a merged grid
  • Case-Community-DualGrid-V5-mashup
    • Has 2 grids and a slider which any one of the 3 widgets can be updated and the change will be reflected in the others.
This is an example. I am sure you could modify the example to remove the slider if that is your goal.
If this address your questions please identify as an acceptable solution.
@aitc-plmsupport,
Why do you have them in 2 Grids?
Build a service which accepts the 2 infotables and output a single infotable which can then be displayed and will scroll together.
Just a suggestions.
11-Garnet
February 6, 2023
Hi @PEHOWE
I have the same question too.
I have two advanced tree grid displaying one data from PLM and another from SAP.
In my case it cannot be merged into one infotabe/grid ,  I should display them individually still want them to be synchronized when user scrolls the grid rows.
How can I achieve the same.
Janakiraman P
AITC,
I really don't know if it will help or not.  Sounds like it would be a really cool feature if you can get it working...doesn't matter WHY you want/need it...
I did some searching around on my go-to javascript answer site and found this:
https://stackoverflow.com/questions/9236314/how-do-i-synchronize-the-scroll-position-of-two-divs
The accepted solution is to use jQuery and makes use of the scrollTop() function.  Will it work in TWX?  I don't know, but maybe it will give you a start down the right path.  If you hit on a solution, please share!  Thanks!!
@aitc-plmsupport
@OldGoat
There is an article which as information on using JQuery :  Article - CS342798
How to use jQuery Plugin or external JavaScript plugins in ThingWorx and in Mashups
@aitc-plmsupport,
One approach is to do something like:
In this case I have 2 visible InfoTables and a service behind the button which takes the inputs and outputs a merged table.
Because you said that is not your goal I took another look:
In this case selecting the left grid, updates the slider and the selected row on the right grid.
I also had the slider change which is updating the selected the rows in both grids.
I have not loaded enough rows to determine the behavior when the grid adds scroll bars.
Let me know if this is what you are trying to accomplish
Pehowe
PEHOWE17-PeridotAnswer
