Refer - House Template example in developer tutorial
I have House template that implements BulbThing (with On/Off and luminance properties) shape.
I have to create a house thing having 4 bulbs , how to do it ?
hi
you create separate thing for each bulb(ie bulb1,bulb2,..) and use House template as ThingTemplate.
regard,
dinesh
Hi Aniruddha, as dinesh already noted, as it appears from the description that you already have your Home Template implementing BulbThingShape, then just by creating Things that inherit HomeTemplate you will have all the properties/characteristics of BulbThingShape included
