Hi Everyone,
I have a requirement like suppose I have a dropdown of different states now If I select a particular state it show data associated with that state in Grid data format and also their distinct count on bar chart.
now my requirement is when user filter data based on different column name then the data in pie chart should change how can I configure this thing
What I have done is through SQL queries I am taking distinct count of each column and showing that on bar chart. My requirement is now if user click on filter of the data for that used (data filter widget for grid data) then that should also trigger the data of bar chart and shows the exact count based on filtered data.
Lav
Hi @LY_10691079 ,
Hi @LY_10691079
May I suggest adding a few details about your questions? It may help others to engage. We are suggesting a few "question best practices" here.
Hi @LY_10691079 ,
