How to post an image from ThingWorx to an external web server using REST API?
vvaidya
Hi All,
I am trying to post/send an image which is stored as a property in TW to an external web server using Rest API. I have used POSTImage snippet to try this out. But  I am getting the below error
Wrapped java.lang.Exception: Unable To Convert From [B to JSON Cause: Unable To Convert From [B to JSON
I am not very sure if  PostImage snippet is actually meant to meet the above requirement.
Is there any other way?
Thanks and Regards,
Vishal Vaidya
miikkae
(To:vvaidya)
I'm pretty new to whole ThingWorx and havent' tried posting images but have you thought about base64 encoding the image as a string, submitting that, and converting back to image on ThingWorx side?
This was just an idea on top of my head. Not that ThingWorx specific solution.
vvaidya
(To:miikkae)
Thanks Miikka,
Even i thought the same but not sure how to encode image as string in Thingworx. Though there are snippet available but i have not come across any proper example where image is encoded in string or vice versa using base64EncodeBytes or similar services.
Vishal Vaidya
