Is there a way to programmatically duplicate an entity? It seems some entities don't have thing templates, so they cannot be created with a thing template.
Hi @Velkumar
I wanted to know how to duplicate a thing in case I'm not able to access the 'Scheduler' thingTemplate in TWX 8.5.3 mentioned in my other post.
I found a few services for cloning entities under "EntityServices".
Hi @Willie
It is not possible to duplicate entities programmatically. Could you please explain your use case so we can find some workaround?
/VR
Hi @Velkumar
My bad I didn't check for keyword clone. Great
