I have an HTML piece of code (for the runtime of the custom widget) that works using the widget property value. Currently, when I hard code the property value of the widget within the mashup it is working as required but when I bind the output of a service to the property value of the widget, it is not working.
Is there a way for me re-render the HTML once the property value is updated from the service? The service is called on mashup loaded.
Thanks in Advance
Can you explain what is happening when it fails to work as expected? Can you provide your mashup so we can take a look?
Regards.
--Sharon
