How to read any image from SystemRepository using Service and display on image widget
ranjank
Pls help on this logic
1 ACCEPTED SOLUTION
Ashritha
(To:ranjank)
Since Image widget uses the Media entity to display image, it is not possible to display image from System Repository using Image widget. Instead use following steps :
Use Service :
var Content = Things["SystemRepository"].LoadImage({
path: undefined /* STRING */
path: complete path of image
Use Value Display widget :
  1. Bind output of above service to value display
  2. Click on Render and State
  3. Change the Renderer to Image in the drop down
  4. Done and Save
2 REPLIES 2
Ashritha
(To:ranjank)
Use Service :
  4. Done and Save
anarwal
(To:ranjank)
 Hi @ranjank ,
If above response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
