How to remove the Blog Widget internal buttons, such as the Search button
LY_8501333
Hello,everyone,
    I'm a novice. I'm doing a Blog Widget, trying to remove some of the buttons in Blog Widget, such as Search, View, Sort By, and how to do it?
Thank you!
dupatel
(To:LY_8501333)
li yaping​ : I believe those are standard feature available with Blog Widget and can be set to different values by modifying properties. In case you need something specific then I believe you might have to create a custom widget which provide desired functionalities.
-Durgesh
