Please guide me to send a text file using java sdk to thingworx platform
Hi... you can check FileTransferVirtualThing API
It's in the com.thingworx.communications.client.things.filetransfer package
There's an API overview in your Java SDK zip under doc/html - just open the index.html
Hi dibya ranjan mishra,
Have you looked at the FileTransferExample which is packaged with Java Edge SDK? It should help in your issue.
hello ankit,
I have gone through the FileTransferExmaple.java and FileTransferExampleHelper.java
I have a doubt regarding virtual directories. I mean can you explain me the following few lines
this was in the sample code:
// Add two virtual directories that will act as the root directories
// in this application's virtual file system.
// The first field is the name of the directory
// The second field is the path
myThing.addVirtualDirectory("in", "E:/");
myThing.addVirtualDirectory("out", "E:/");
Hi...
in this example, the virtual directory defines a repository (named "in" or "out") and maps it to E:/ on your disk (absolute path in the file system)
The description is a bit better in the .NET SDK section of the Help Center though...
You can then use the repository alias later on to directly execute create / read / write actions in the mapped folder.
Cheers,
Michael
