How do I use the LoadBinary Service of FileRepository TT to convert a pdf file in my SystemRepository to array/stream of bytes and assign it to a blob type property of a separate Thing.
Currently, If I'm running the LoadBinary service with the file path as input in the Composer for the SystemRepository Thing, nothing is returned by the service.
Hi @ravi2.
In our testing, we were able to load a .pdf to a blob successfully. We received a "No result" but were then able to validate that the object did exist in the blob. Is this possibly what is happening in your case?
// Content: BLOB
var Content = Things["SystemRepository"].LoadBinary({
path: "/FILE_NAME_HERE.pdf" /* STRING */
me.MyBlobProperty = Content;
Another possibility could be the path. Are you using the relative path for your System Repository?
--Sharon
Hi @ravi2.
// Content: BLOB
--Sharon
