Hi, I want to make a kind of Facebook notify icon when I have new alerts.
I created a helper thing with these properties:
NumberOfNewAlerts //Number
HasNewAlerts //Boolean
NumberOfUnackAlerts //Number
HasUnackAlerts //Boolean
through a subscription in my template (where the event is the new alert) I set NumberOfNewAlerts +=1 and HasNewAlerts = true.
I would like a service that, anytime I open my AlertMashup, will set
NumberOfNewAlerts =0 and HasNewAlerts = false.
Is there a way to know when I open my page?
Plus, this service must depend per user because if I have three users (A, B and C) which are allowed to see the project; I want that NumberOfNewAlerts refers to the actual new alerts to the user.
Fabio, if you always want to trigger that when opening a page, you can possibly write a service to fetch and set your value (something like GetProperties) and set that to trigger at Mashup Load.
Yes, I've done something quite similar but my actual problem is:
Let's say I have my alert's page open and I keep it open of one hour.
Since my service triggers at opening page I have my values reset when I open it;
but if a new alerts happens in that hour I don't want my NumberOfNewAlerts properties to increase because, if my Alert Page is open I guess I am already seeing new alerts incoming.
I don't know if I was clear enough.
So, in other words, I want my subscription which sets NumberOfNewAlerts +=1 and HasNewAlerts = true only works when Alert Mashup page is closed.
I don't believe you can track if a page is open or not. If you use Popup Mashups, for example, you can trigger a 'close popup' event; that doesn't hold up for standard Mashups. I was going to suggest using user session information next, but that would hold true for the entire user session, regardless of whether the Mashup is open or closed.
Hi, in the version 7.2.0 release notes, there's a feature enhancement of Mashup Builder: "Added the ability to update properties automatically in a mashup". I don't know what does it mean exactly but maybe it could help.
