How to set a value on opening a page
fmanniti
9-Granite
Hi, I want to make a kind of Facebook notify icon when I have new alerts.
I created a helper thing with these properties:
NumberOfNewAlerts //Number
HasNewAlerts //Boolean
NumberOfUnackAlerts //Number
HasUnackAlerts //Boolean
through a subscription in my template (where the event is the new alert) I set NumberOfNewAlerts +=1 and HasNewAlerts = true.
I would like a service that, anytime I open my AlertMashup, will set
NumberOfNewAlerts =0 and HasNewAlerts = false.
Is there a way to know when I open my page?
Plus, this service must depend per user because if I have three users (A, B and C) which are allowed to see the project; I want that NumberOfNewAlerts refers to the actual new alerts to the user.
Aanjan
9-Granite
(To:fmanniti)
Fabio, if you always want to trigger that when opening a page, you can possibly write a service to fetch and set your value (something like GetProperties) and set that to trigger at Mashup Load.
fmanniti
9-Granite
(To:Aanjan)
Yes, I've done something quite similar but my actual problem is:
Let's say I have my alert's page open and I keep it open of one hour.
Since my service triggers at opening page I have my values reset when I open it;
but if a new alerts happens in that hour I don't want my NumberOfNewAlerts properties to increase because, if my Alert Page is open I guess I am already seeing new alerts incoming.
I don't know if I was clear enough.
So, in other words, I want my subscription which sets NumberOfNewAlerts +=1 and HasNewAlerts = true only works when Alert Mashup  page is closed.
Aanjan
9-Granite
(To:fmanniti)
I don't believe you can track if a page is open or not. If you use Popup Mashups, for example, you can trigger a 'close popup' event; that doesn't hold up for standard Mashups. I was going to suggest using user session information next, but that would hold true for the entire user session, regardless of whether the Mashup is open or closed.
qngo
(To:fmanniti)
Hi, in the version 7.2.0 release notes, there's a feature enhancement of Mashup Builder: "Added the ability to update properties automatically in a mashup". I don't know what does it mean exactly but maybe it could help.
