I have some base 64 content of a PDFs. I want to show them on mashup. Using Iframe I can show it normal html page but, not in thingworx mashup.
I have done showing pdf from external URL, pdf from repository but not getting successful using base 64 content. I am attaching few files for the reference.
Save as attached file into .htm file and you can see it in browser. I am using same text in TEXT property of "htmltextarea" widget in thingworx (9.1.0-b10877). But it is not showing anything. By inspecting the page I can see it only show html tage with empty body.
Regards
Shyam
Hello All,
I just found a way after trying many ways. Follow below steps to complete this. I am using Thingworx version (9.1.0-b10877).
1. Take a "ptcsvaluedisplay" widget.
2. Find "ValueFormat" property and click "Renders & State" button in front of this property.
3. In the "Renderer" dropdown, select "HTML".
4. In the "Format" dropdown, select "With Formatting, Unsanitized (not-secure)".
5. Bind the result of service to the (* data) of this "ptcsvaluedisplay" widget.
6. Result of service should be in below format. Replace |--------| in below format with the base 64 content.
<iframe src="data:application/pdf;base64, |---------| " height="100%" width="100%" frameborder="0"></iframe>
Happy hunting.
Regards
Shyam
Hello All,
Happy hunting.
Regards
Shyam
