Hi Team,
Suppose, my service is returning 1 String field and 2 Integer fields.
The string field will take the X-axis but want to show only 1 series in Y axis out of those two integer fields.
How to achieve this behaviour as there is no flexibility to select Y axis field in properties.
The All data is binded to Data property of Bar chart widget. Thingworx version is 9.0
Please help.
Thanks in advance.
Maybe use the 'Stack Bar'?
Else in the service returning the data, resolve those two columns into a single column?
It seems this has been deprecated?
Hi @RK_0705.
Was the previous response helpful in finding a solution? If so, please mark it as the Accepted Solution for the benefit of others in the community.
If you're still searching for a solution, please let us know.
Regards.
--Sharon
