How to solve SSLHandshakeException?
  • July 17, 2017
  • 5 replies
  • 12857 views
Hi all,
I am now using getJSON function to get the content from an url, and the code is shown as below:
var params = {
proxyScheme: undefined /* STRING */,
headers: undefined /* JSON */,
ignoreSSLErrors: true /* BOOLEAN */,
useNTLM: undefined /* BOOLEAN */,
workstation: undefined /* STRING */,
useProxy: true /* BOOLEAN */,
withCookies: undefined /* BOOLEAN */,
proxyHost: 'proxy.companyname.com' /* STRING */,
url: "http://gateway-a.watsonplatform.net/visual-recognition/api/v3/classify?api_key=9cf5fa21fe8ff3d9eaa49d0319f329ae5ee7bb89&…" /* STRING */,
timeout: undefined /* NUMBER */,
proxyPort: '8080' /* INTEGER */,
// result: JSON
var result = Resources["ContentLoaderFunctions"].GetJSON(params);
I got the error message below:
Wrapped javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target Cause: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
But when I change the url to https://feeds.citibikenyc.com/stations/stations.json, can get the content.
Can anyone help solve this problem? Thank!
Best answer by CRArko
Hi.
With that kind of error reported the cause is often that the certificate is missing from the Java keystore.
Is this a self-signed certificate? If so, try this procedure out:
Import the self-signed certificates from the external server into the ThingWorx trust store using the following steps:
  • Locate trust store used by ThingWorx
    • Enable SSL logging if needed by adding the following parameter: -Djavax.net.debug=ssl
    • Restart Tomcat
    • Review Catalina and stdout logs for the following line:
trustStore is: C:\Program Files\Java\jre1.8.0_141\lib\security\cacerts
  • Download the InstallCert.java script to the ThingWorx machine in the same location as the cacerts file identified above
  • Execute: javac InstallCert.java
  • Execute: java InstallCert externalserver:port
  • The Java application will prompt you to install the external certificate
  • A new jssecacerts should be generated with the external certificates in the same location as the cacerts file
  • Restarting Tomcat will indicate a new trust store: trustStore is: C:\Program Files\Java\jre1.8.0_141\lib\security\jssecacerts
  • Retest the operation that was failing earlier with the PKIX error
Let us know if this is successful or not.
-- Craig A.
yzhang11-VisitorAuthor
The API key needs to be updated, but not influence the result.
Hi Ying Nang Zhang,
Is your problem resolved? I have a similar problem here.
Any response to this? I also am having this problem.
Was this on ThinWorx version 8?
I am seeing similar error, not sure what the core issue is?
How did you solved the problem?
I am having the same problem.
madhu
I had the same problem (EC2 Amazon Linux server, using TWX 8.1 Docker PostgreSQL), and it was not a self-signed certificate. The following worked for me:
Stop ThingWorx:
$ docker stop twxfoundation
Go to https://www.target_address.com/ and click on lock icon to view SSL certificates
Open Certificate and view Certificate Path - download each certificate in that path (Details -> Copy to File). Use first export option (must be X.509 certificate)
Upload downloaded certificates to your ThingWorx server
Import certificates into Docker keystores into TWX server, use following for reference:
https://adamtuttle.codes/TIL-adding-a-jvm-ssl-cert-docker/
https://stackoverflow.com/questions/21076179/pkix-path-building-failed-and-unable-to-find-valid-certification-path-to-requ/36427118#36427118
Find keystores in your TWX server (in my case Docker keystores, with a path that included "/docker/overla2"):
$ sudo find / -iname 'cacerts'
Import each certificate into each keystore, for example (storepass is "changeit" by default):
$ sudo keytool -importcert -alias myApiCert -keystore "/data/docker/overlay2/blahblah123/diff/opt/jdk1.8.0_92/jre/lib/security/cacerts" -file my_api_cert.cer -noprompt -storepass changeit
I got this problem, while installing ThingWorx Navigate when connecting to Windchill,
I have solved it importing the Windchill signing certificate into Java Keystore.
madhu
CRArko5-Regular MemberAnswer
Hi.
    • Restart Tomcat
-- Craig A.
Hi Craig A.,with "java InstallCert externalserver:port",what the "port"should be?Thanks.
