We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
I'm quering a stream and based on the values inside I decide what columns to remove.
I managed to return the infotable succesfully and to display it on the mashup.
I have 1 column (Known name) which appears in the end (Not sure if always at the end) and I want it to be the first column in the infotable.
The service is returning infotable without data shape as not all the columns are always shown.
Create a basic datashape that has at least the one column you want as the first data grid column. Then append your other columns programmatically.
