How to update scan rate at a time to few properties industrial thing using service in Thingworx 9
vi1
How to update scan rate for few properties to Kepware industrial thing at a time using service instead of updating one by one  property in Thingworx 9.5.
I am trying to update scanrate to few properties using service but SQL transaction log size is increasing. Because , updating scan rate one by one property using below service. Is there way update scan rate at a time ?
I am using below code.
for(let i = 0; i < propertynamelist.length; i++) {
 Things[remotething].SetRemotePropertyBinding({
propertyName: propertyName /* STRING */ ,
aspects:
          scanRate: 480000  // Update only the scan rate aspect
Thanks&Regards,
Latha
wcui
(To:vi1)
Hi @vi1
This is a known issue when calling SetRemotePropertyBinding frequently because the service execution changes Thing definition so it adds a new record to Thing Change History which writes a new row to ThingWorx persisten database.
You can export the xml file of the Industrial thing and manually updated scanrate settings(aspect.scanRate="1000") then import xml file.
This will add only one new record to Thing Change history.
I am afraid currrently there is no other workarounds for this issue.
wcui
(To:vi1)
Hi @vi1
vi1
(To:wcui)
Thank you for reply. Is there automated service, Instead of Manual Export and Import for updating scan rate? Can we use wait after updating scan rate first property?
wcui
(To:wcui)
@vi1
I am afraid SetRemotePropertyBinding is the only available automated service.
For batch updating scanrate of remote property, either to perform Export/Import or to change scanrate settigs from Composer manually.
