I would like to upload some files to azure container via SFTP, please help me with the best practices.
thanks,
Janakiraman
try this extension https://github.com/thingworx-field-work/SftpExtensionTWX
Not sure if you have TWX Flow? If you have you could use the FTP connector
https://support.ptc.com/help/thingworx/flow/r9/en/#page/flow/flow/FTP/FTPConnector.html#
As you have been provided with a few options for addressing your need, it would be appreciated if you could designate the one that worked for you as the Accepted Solution, for the benefit of other Community Members who may have the same question.
Thanks for using the PTC Community!
--Sharon
