I wish sending local file to thingworx server pc.
Is this right?
invokeService has timeout so I confused copy function timeout.
com.thingworx.types.collections.ValueCollection vc = new com.thingworx.types.collections.ValueCollection();
vc.SetStringValue("sourceRepo", "");//i don't know this
vc.SetStringValue("sourcePath", @"c:\\test");
vc.SetStringValue("sourceFile", "test.txt");
//elide
//elide
invokeService(ThingworxEntityTypes.Resources, " FileTransferSubsystem", "Copy", vc, 10000);
public InfoTable Copy(java.lang.String sourceRepo, java.lang.String sourcePath, java.lang.String sourceFile, java.lang.String targetRepo, java.lang.String targetPath, java.lang.String targetFile, java.lang.Integer timeout, java.lang.Boolean async) throws java.lang.Exception
When you do the configuration for the agent, you should be configuring repos (file storage locations) on the drive that will have an alias, that would be the sourceRepo
