Hi all,
I'm trying to use window.print() command in expression but I'm getting error as "You can't use window in an expression". Is there any possible way to use window command in expression/validator ?
Thanks in Advance.
VR
That unfortunately is blocked/not available.
I know location is available not sure what else is available.
Potentially you can create a custom extension to get the functionality that you need. (Not my area of expertise)
