How to using json basetype in custom widget and without using infotable(use json object which is returned from service....directly)
jlin-4
Steps:
1.Ready a custom widget and define the widget properties as following:
  xxx.ide.js=>
this.widgetProperties = function () {
    return {
      'name': 'custom widget',
      'description': 'custom widget.',
      'category': ['Common'],
      'properties': {
          'Data1': {
              'description' : 'data',
              'isBindingTarget': true,
              'isVisible': true,
              'baseType': 'JSON',//not using infotable
              'warnIfNotBoundAsTarget': false
2. Using the json obj as following:
xxx.runtime.js=>
if (updatePropertyInfo.TargetProperty === "Data1") {
   //How to get json here???
You can get the JSON object like this
if (updatePropertyInfo.TargetProperty === 'JSONData') {
            var json= {};
            if(updatePropertyInfo.RawDataFromInvoke!=undefined) {
                json = updatePropertyInfo.RawDataFromInvoke;
          /* do whatever */
Be carefull, that piece of code is only working with a service that only return the JSON data.
Your navugator degugger is your friend, I always verify with the content of the updatePropertyInfo variable.
It's content change if you're passing a singleProperty or an infotable.
Hope it's help.
Regards
Be careful,
If your widget is binded to an infotable JSON property, composer give you the entire infotable, I don't understand why.
It's seems to be a bug.
In that case I retrive the value as below
var json = {};
    if(updatePropertyInfo.RawDataFromInvoke.rows!=undefined && updatePropertyInfo.RawDataFromInvoke.rows.length>0) {
        //come from infotable binding
        json = updatePropertyInfo.RawDataFromInvoke.rows[0].MYJSONPROPERTY;
    else {
        //come from direct service output
That's very ugly to to your datashape variable name into the widget code, but.... it works
My Thingworx version is 7.1.4
Regards
