There is a DataTable as below. How to get rows containing "%" ?
| ID | Value |
1
%1
2
2?
3
4
+1
In above case, should be the 1st row.
Because % is a wildcard in Thing Query, how should I escape it?
Same question for ? and *.
Try the following code to just return the "%1" line
var query = {
"filters": {
"fieldName": "value",
"type": "LIKE",
"value": "\\u0025" + "1"
var params = {
query: query /* QUERY */
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryDataTableEntries(params);
The % is unescaped into \\u0025 to reflect the hex number of the character
https://www.ascii.cl/htmlcodes.htm
For me it returned only this one row out of
%1
2?
+1
11
12
21
22
var query = {
"filters": {
"type": "LIKE",
var params = {
%1
2?
+1
11
12
21
22
check Unicode List (0000-0FFF) from here
https://ja.wikipedia.org/wiki/Unicode%E4%B8%80%E8%A6%A7_0000-0FFF
The Unicode marking method also works for below characters. It should be a common way for all characters.
