I am facing a problem with using customized styles in navigation widget.
psaxena
When I use my own styles in navigation widget then it is picking the default styles of navigation and not my custom styles. When I refresh the mashup it picks the default navigation styles.
ankigupta
(To:psaxena)
Priyanshi Saxena​, Which ThingWorx version are you on? Can't reproduce it on my local instance 7.3.1
And also are you using +custom option for custom style or creating a style definition first and using it in your mashup.
Hi Ankit,
I amusing Thingworx 6.6 and yes I created the style using +Custom .
jkaczynski
(To:psaxena)
Hello Priyanshi Saxena​,
Have you set your custom StyleDefinition in the Navigation widget configuration? Which version of the Thingworx do you use?
Hi Jakub,
Yes I have set the custom style in the widget also. I am using Thingworx version 6.6 and the problem specially exists with Navigation Hover style.
