07-Sep-2017 16:10:41.089 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.46
07-Sep-2017 16:10:41.094 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Aug 10 2017 10:10:31 UTC
07-Sep-2017 16:10:41.095 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.46.0
07-Sep-2017 16:10:41.095 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
07-Sep-2017 16:10:41.096 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
07-Sep-2017 16:10:41.096 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
07-Sep-2017 16:10:41.097 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_144
07-Sep-2017 16:10:41.097 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_144-b01
07-Sep-2017 16:10:41.097 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
07-Sep-2017 16:10:41.098 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
07-Sep-2017 16:10:41.098 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
07-Sep-2017 16:10:41.099 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
07-Sep-2017 16:10:41.099 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
07-Sep-2017 16:10:41.100 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
07-Sep-2017 16:10:41.101 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
07-Sep-2017 16:10:41.102 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
07-Sep-2017 16:10:41.102 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
07-Sep-2017 16:10:41.103 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
07-Sep-2017 16:10:41.103 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
07-Sep-2017 16:10:41.106 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library 1.2.14 using APR version 1.6.2.
07-Sep-2017 16:10:41.109 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
07-Sep-2017 16:10:42.159 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized (OpenSSL 1.0.2l 25 May 2017)
07-Sep-2017 16:10:42.348 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-80"]
07-Sep-2017 16:10:42.535 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
07-Sep-2017 16:10:42.539 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-apr-8008"]
07-Sep-2017 16:10:42.546 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1914 ms
07-Sep-2017 16:10:42.583 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
07-Sep-2017 16:10:42.583 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.46
07-Sep-2017 16:10:42.613 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
07-Sep-2017 16:10:56.778 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
What is youir version of ThingWorx platform? Could you please attach the apllicationlog.log found in ThingworxStorage/logs?
Did you configure Tomcat with the following Java Option:
-Djava.library.path=D:\tomcat8\webapps\Thingworx\WEB-INF\extensions
And ensure that the license.bin file is in the ThingworxPlatform directory?
Thank you James McCuen. Its working now
