I installed Cygwin also. But I was not able to run the makefile. Any help is appreciated. Thanks in advance!!
Bhargavf, which version of C SDK are you using and what's the error that you are getting? I believe the new version of C SDK can automatically detect the architecture information, which was not there in the older version of CSDK
The Latest Version. I am trying to execute with C compilers like DevC++. After that I tried to use makefile. But I have no idea how to deal with makefiles.
I am not getting any errors. It's just that have no idea to work with makefile.
I am a noob in this .Help me solve this.
There's quite useful utility for Windows (other OS platforms too), CMake . I'd suggest you to go through it, download and install it. There's also Documentation | CMake for you to set it up and get your initial application running.
If you are starting for the first time make sure to begin with the example code/app provided with the C SDK, it'll be quite helpful for you build initial understanding about the C SDK.
Hope this would help.
